Ana içeriğe geç
HP Compaq Presario CQ56-110US Disassembly
Neye ihtiyacın var
  1. HP Compaq Presario CQ56-110US Disassembly, Removing Battery: adım 1, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing Battery: adım 1, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing Battery: adım 1, 3 resimden 3.
    • Remove Battery by sliding the tab
    Thank you for a great work and an excellent clarification for all parts of the device
    abbas hussein - Yanıt
  2. HP Compaq Presario CQ56-110US Disassembly, Removing Ram Cover: adım 2, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing Ram Cover: adım 2, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing Ram Cover: adım 2, 3 resimden 3.
    • Remove the 3 screws from the Ram Cover and lift up the cover
  3. HP Compaq Presario CQ56-110US Disassembly, Removing Ram Sticks and Wifi Card: adım 3, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing Ram Sticks and Wifi Card: adım 3, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing Ram Sticks and Wifi Card: adım 3, 3 resimden 3.
    • Remove Ram Stick by pulling the tabs to it side
    • Remove the to remove the Wifi Card and remove its antenna wires
  4. HP Compaq Presario CQ56-110US Disassembly, Removing Hard Drive Cover: adım 4, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing Hard Drive Cover: adım 4, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing Hard Drive Cover: adım 4, 3 resimden 3.
    • Remove 2 Screw from the Hard Drive Cover and lift up the cover
  5. HP Compaq Presario CQ56-110US Disassembly, Removing the Hard Drive: adım 5, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing the Hard Drive: adım 5, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing the Hard Drive: adım 5, 3 resimden 3.
    • Remove the 3 screws from the Hard Drive
    • Remove the SATA Cable from the Hard Drive and Motherboard
  6. HP Compaq Presario CQ56-110US Disassembly, Removing Screws: adım 6, 1 resimden 1.
    • Remove 10 screws from the laptop
    • Remove 3 2.5 x 6.5 screws from the laptop
    • Remove 3 2.5 x 5 screws from the laptop
    • Remove 4 2.5 x 3 screws from the laptop
    • *The Photo looks incomplete because it exceeded the crop limit
  7. HP Compaq Presario CQ56-110US Disassembly, Removing the Keyboard: adım 7, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing the Keyboard: adım 7, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing the Keyboard: adım 7, 3 resimden 3.
    • Put Your Hands on the Top Corners and Put some little pressure
    • Be careful that there is a ribbon cable under there and make sure that it is removed
  8. HP Compaq Presario CQ56-110US Disassembly, Removing Top Cover: adım 8, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing Top Cover: adım 8, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing Top Cover: adım 8, 3 resimden 3.
    • Remove the Ribbon Cables and Wires from the Motherboard and use a pick to remove the top cover
    • Remove 1 screw and lift up the top cover
  9. HP Compaq Presario CQ56-110US Disassembly, Removing the CD Drive: adım 9, 2 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing the CD Drive: adım 9, 2 resimden 2.
    • Remove the CD Drive by Pushing or Pulling to the outside
  10. HP Compaq Presario CQ56-110US Disassembly, Removing the Display Cable: adım 10, 2 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing the Display Cable: adım 10, 2 resimden 2.
    • Remove the 3 Display Cables and a USB Port Ribbon Cable
  11. HP Compaq Presario CQ56-110US Disassembly, Remove Motherboard Screws: adım 11, 2 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Remove Motherboard Screws: adım 11, 2 resimden 2.
    • Remove 2 Screws from the Motherboard
  12. HP Compaq Presario CQ56-110US Disassembly, Removing the Motherboard: adım 12, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing the Motherboard: adım 12, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing the Motherboard: adım 12, 3 resimden 3.
    • Remove the Power Cable and pull the motherboard to the right
  13. HP Compaq Presario CQ56-110US Disassembly, Removing the CPU Heatsink: adım 13, 2 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing the CPU Heatsink: adım 13, 2 resimden 2.
    • Remove the Six Screws from the Heatsink
    • Remove the Cable of the fan
  14. HP Compaq Presario CQ56-110US Disassembly, Removing the CPU: adım 14, 3 resimden 1. HP Compaq Presario CQ56-110US Disassembly, Removing the CPU: adım 14, 3 resimden 2. HP Compaq Presario CQ56-110US Disassembly, Removing the CPU: adım 14, 3 resimden 3.
    • Use Something Flat Tipped like a Flat tip screw driver
    • Be Careful with removing the CPU because it has fragile pins under it, remove it by wiggling it back and forth
  15. HP Compaq Presario CQ56-110US Disassembly, And We're Done.....: adım 15, 2 resimden 1. HP Compaq Presario CQ56-110US Disassembly, And We're Done.....: adım 15, 2 resimden 2.
    • Laptop Dissasembly Complete, Here is Everything except for the Case and Display
    Thank you so much . I learned to unlock the device by following the illustrations
    hussein abbas - Yanıt
Sonuç
To reassemble your device, follow these instructions in reverse order. This can be useful for a CPU Upgrade
7 farklı kişi bu kılavuzu tamamladı.
Macix26
485 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 58
Her zaman: 2,158
