Ana içeriğe geç
HP Compaq Presario CQ56-110US Keyboard Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: adım 1, 2 resimden 1. HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel.
    • Push the latch to the unlocked position.
  2. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 2, 1 resimden 1.
    • Gently take out the battery.
  3. HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • On the back panel of the laptop are two screws which have a keyboard symbol next to them.
    • Using a Phillips screwdriver with a PH0 bit, remove both the 7mm and 5.5mm screws.
  4. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 4, 2 resimden 1. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 4, 2 resimden 2.
    • From left to right, unscrew the 5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver.
  5. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 5, 2 resimden 1. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the RAM panel by unscrewing the three screws with the PH0 Screwdriver Bit.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool
    • Remove the RAM panel using a plastic opening tool.
  6. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 6, 1 resimden 1.
    • Inside the RAM panel, use the screwdriver to remove the 5mm screw pictured.
  7. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 7, 1 resimden 1.
    • Flip the laptop back over and lift the lid to expose the keyboard.
  8. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 8, 2 resimden 1. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to pry up the keyboard.
  9. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 9, 2 resimden 1. HP Compaq Presario CQ56-110US Keyboard Replacement: adım 9, 2 resimden 2.
    • Once the keyboard is lifted, disconnect the band.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Iyonna L. Tynes
446 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G4
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Difficulty HARD ? oh please… please change to EASY… just some screws?
Assembler Computer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 3,473
