Giriş
Use this guide to replace the entire keyboard if it is unresponsive or not functioning properly.
Neye ihtiyacın var
Videoya Genel Bakış
Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel.
Push the latch to the unlocked position.
On the back panel of the laptop are two screws which have a keyboard symbol next to them.
Using a Phillips screwdriver with a PH0 bit, remove both the 7mm and 5.5mm screws.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Difficulty HARD ? oh please… please change to EASY… just some screws?
