Ana içeriğe geç
HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 1. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 2. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 3.
    • Use a Phillips screwdriver with a PH1 bit to loosen the three indicated screws.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool.
  2. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement: adım 2, 2 resimden 1. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Gently pull the black and white cables to disconnect them from the Wi-Fi card.
  3. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Use the same screwdriver to remove the two 3 mm screws holding the card in place.
  4. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • Lift the Wi-Fi card to remove it from the slot.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Blanette Baltimore
255 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 21
Son 30 gün: 26
Her zaman: 1,053
