Ana içeriğe geç
HP Compaq Presario V6000 Trackpad Replacement
Neye ihtiyacın var
  1. HP Compaq Presario V6000 Trackpad Replacement, Trackpad: adım 1, 1 resimden 1.
    • Use the metal spudger to gently remove the plastic plate from the rest of the top panel.
    • Be careful not to break the plastic tabs connecting the two top panels.
  2. HP Compaq Presario V6000 Trackpad Replacement: adım 2, 1 resimden 1.
    • Separate the connection of the top piece from the board.
  3. HP Compaq Presario V6000 Trackpad Replacement: adım 3, 1 resimden 1.
    • Remove the connection from the keyboard to its housing.
  4. HP Compaq Presario V6000 Trackpad Replacement: adım 4, 1 resimden 1.
    • Separate the power connections.
  5. HP Compaq Presario V6000 Trackpad Replacement: adım 5, 1 resimden 1.
    • Unravel the wire.
  6. HP Compaq Presario V6000 Trackpad Replacement: adım 6, 1 resimden 1.
    • Remove the screws connecting the plastic housing to the screen.
    • Use caution when removing the last screen. Do no damage the screen.
  7. HP Compaq Presario V6000 Trackpad Replacement: adım 7, 1 resimden 1.
    • Make sure to grip the screen tightly and separate the top and bottom.
  8. HP Compaq Presario V6000 Trackpad Replacement: adım 8, 2 resimden 1. HP Compaq Presario V6000 Trackpad Replacement: adım 8, 2 resimden 2.
    • Remove the screws that hold the track pad in place.
    • Remove the track pad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
adam
323 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 38-4, Bennett Fall 2016 Texas Tech, Team 38-4, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S38G4
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 649
