Ana içeriğe geç
HP Compaq Presario V6000 Wifi antenna card Replacement
Neye ihtiyacın var
  1. HP Compaq Presario V6000 Wifi antenna card Replacement, Wifi antenna card: adım 1, 1 resimden 1.
    • Grab a Type-Cross #1 screwdriver and unscrew the 3 screws and take off the cover of the wifi antenna card.
  2. HP Compaq Presario V6000 Wifi antenna card Replacement: adım 2, 1 resimden 1.
    • Use your finger tips to pry off the gray antenna connections.
    • Be careful to not pull the antenna wire too hard, you may cause damage to the connection permanently and/or motherboard.
    • The screwdriver is only being use to demonstrate which wire to remove. The screwdriver can potentially damage the motherboard if used improperly.
  3. HP Compaq Presario V6000 Wifi antenna card Replacement: adım 3, 1 resimden 1.
    • After removing the connection cable, remove the two screws that hold the wireless card to the motherboard.
    • Then gently remove card without causing any damage to card itself or surrounding parts.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hunter Griffin
104 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 38-4, Bennett Fall 2016 Texas Tech, Team 38-4, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S38G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 733
