Ana içeriğe geç
HP Compaq Presario cq62-214nr Motherboard Replacement
Neye ihtiyacın var
  1. HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: adım 1, 2 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
  2. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 2, 2 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 2, 2 resimden 2.
    • In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
    • In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
  3. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 3, 3 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 3, 3 resimden 2. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 3, 3 resimden 3.
    • Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
  4. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the keyboard by pulling on it with your hands.
    • There is a ribbon cable that is still connected on the back of the keyboard. Do not pull off the ribbon cable when pulling up the keyboard.
  5. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 5, 3 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 5, 3 resimden 2. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 5, 3 resimden 3.
    • Locate the keyboard cable/wire that attaches the keyboard to the laptop .
    • Locate the latch of the wire connector
    • Unlatch the wire connector and gently pull out the wire with your hands
  6. HP Compaq Presario cq62-214nr Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
  7. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 7, 3 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 7, 3 resimden 2. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 7, 3 resimden 3.
    • Locate the three tab holding down the cover of the Motherboard.
    • Lift the tabs with using either a plastic opening tool or your fingers.
  8. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 8, 2 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 8, 2 resimden 2.
    • Using a plastic opening tool to lift the sides of the cover.
  9. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 9, 3 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 9, 3 resimden 2. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 9, 3 resimden 3.
    • Use your hands to gently lift the cover off.
  10. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 10, 3 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 10, 3 resimden 2. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 10, 3 resimden 3.
    • Locate the four cables securing the Motherboard.
    • Gently pull cables to unsecure them.
  11. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 11, 3 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 11, 3 resimden 2. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 11, 3 resimden 3.
    • Remove the three M2.25x5 mm Phillips screws.
  12. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 12, 3 resimden 1. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 12, 3 resimden 2. HP Compaq Presario cq62-214nr Motherboard Replacement: adım 12, 3 resimden 3.
    • Unlatch the final cable and gently remove the Motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Roth Marcelin
726 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,102
