Ana içeriğe geç
HP Compaq Presario cq62-214nr RAM Replacement
Neye ihtiyacın var
  1. HP Compaq Presario cq62-214nr RAM Replacement, Battery: adım 1, 2 resimden 1. HP Compaq Presario cq62-214nr RAM Replacement, Battery: adım 1, 2 resimden 2.
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. HP Compaq Presario cq62-214nr RAM Replacement, RAM: adım 2, 2 resimden 1. HP Compaq Presario cq62-214nr RAM Replacement, RAM: adım 2, 2 resimden 2.
    • Remove the three M2.5x5 mm Phillips screws securing the memory case.
  3. HP Compaq Presario cq62-214nr RAM Replacement: adım 3, 2 resimden 1. HP Compaq Presario cq62-214nr RAM Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, insert it alongside any openings on the case. Lift and slide the tool to remove the case.
  4. HP Compaq Presario cq62-214nr RAM Replacement: adım 4, 2 resimden 1. HP Compaq Presario cq62-214nr RAM Replacement: adım 4, 2 resimden 2.
    • Remove the top RAM chip by lifting up and pulling it towards the left.
    • Once the top RAM chip is removed, remove the one underneath using the same method.
Sonuç
Roth Marcelin
726 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 613
