Ana içeriğe geç
HP Compaq dx2000MT RAM Replacement
Neye ihtiyacın var
    1. HP Compaq dx2000MT RAM Replacement, Removing the HP Compaq dx2000MT Case Doors: adım 1, 1 resimden 1.
      • Turn off your computer and remove the power cable by pulling it straight out of its socket.
      FixBot'a Sor
      Yorum Ekle
    2. HP Compaq dx2000MT RAM Replacement: adım 2, 2 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 2, 2 resimden 2.
      • Remove the two Phillips #2 screws that secure the case door to the device.
      FixBot'a Sor
      Yorum Ekle
    3. HP Compaq dx2000MT RAM Replacement: adım 3, 3 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 3, 3 resimden 2. HP Compaq dx2000MT RAM Replacement: adım 3, 3 resimden 3.
      • Remove the side case door by pushing towards the rear of the device with your hand.
      • This may take considerable force so keep pushing!
      • Once you slide the door back, remove it by pulling it outwards from the device.
      FixBot'a Sor
      Yorum Ekle
    4. HP Compaq dx2000MT RAM Replacement: adım 4, 1 resimden 1.
      • Remove the two Torx T15 screws that secure the case door to the device.
      FixBot'a Sor
      Yorum Ekle
    5. HP Compaq dx2000MT RAM Replacement: adım 5, 3 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 5, 3 resimden 2. HP Compaq dx2000MT RAM Replacement: adım 5, 3 resimden 3.
      • Once again, this may take considerable force.
      FixBot'a Sor
      Yorum Ekle
    1. HP Compaq dx2000MT RAM Replacement, Disassembling HP Compaq dx2000MT Hard Drive: adım 6, 3 resimden 1. HP Compaq dx2000MT RAM Replacement, Disassembling HP Compaq dx2000MT Hard Drive: adım 6, 3 resimden 2. HP Compaq dx2000MT RAM Replacement, Disassembling HP Compaq dx2000MT Hard Drive: adım 6, 3 resimden 3.
      • Remove the IDE data and power cables from the hard drive.
      FixBot'a Sor
      Yorum Ekle
    2. HP Compaq dx2000MT RAM Replacement: adım 7, 3 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 7, 3 resimden 2. HP Compaq dx2000MT RAM Replacement: adım 7, 3 resimden 3.
      • Remove the front bezel by pulling upwards and out from below the lowest air vent.
      FixBot'a Sor
      Yorum Ekle
    3. HP Compaq dx2000MT RAM Replacement: adım 8, 3 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 8, 3 resimden 2. HP Compaq dx2000MT RAM Replacement: adım 8, 3 resimden 3.
      • Remove the external drive faceplate by removing the two Torx T15 screws.
      FixBot'a Sor
      Yorum Ekle
    4. HP Compaq dx2000MT RAM Replacement: adım 9, 2 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 9, 2 resimden 2.
      • Remove the following screws:
      • Front Torx T15.
      • Torx T15 mounting the hard drive cage to the optical drive bay.
      FixBot'a Sor
      Yorum Ekle
    5. HP Compaq dx2000MT RAM Replacement: adım 10, 3 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 10, 3 resimden 2. HP Compaq dx2000MT RAM Replacement: adım 10, 3 resimden 3.
      • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
      FixBot'a Sor
      Yorum Ekle
    6. HP Compaq dx2000MT RAM Replacement: adım 11, 3 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 11, 3 resimden 2. HP Compaq dx2000MT RAM Replacement: adım 11, 3 resimden 3.
      • Remove the two Torx T15 screws holding this side of the hard drive in place.
      FixBot'a Sor
      Yorum Ekle
    7. HP Compaq dx2000MT RAM Replacement: adım 12, 3 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 12, 3 resimden 2. HP Compaq dx2000MT RAM Replacement: adım 12, 3 resimden 3.
      • Proceed to the other side of the hard drive cage.
      FixBot'a Sor
      Yorum Ekle
    8. HP Compaq dx2000MT RAM Replacement: adım 13, 2 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 13, 2 resimden 2.
      • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
      FixBot'a Sor
      Yorum Ekle
    1. HP Compaq dx2000MT RAM Replacement, RAM: adım 14, 2 resimden 1. HP Compaq dx2000MT RAM Replacement, RAM: adım 14, 2 resimden 2.
      • Release the lower portion of the RAM by pushing down on the bottom tab.
      FixBot'a Sor
      Yorum Ekle
    2. HP Compaq dx2000MT RAM Replacement: adım 15, 2 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 15, 2 resimden 2.
      • Release the upper portion of the RAM by pushing down on the upper tab.
      FixBot'a Sor
      Yorum Ekle
    3. HP Compaq dx2000MT RAM Replacement: adım 16, 3 resimden 1. HP Compaq dx2000MT RAM Replacement: adım 16, 3 resimden 2. HP Compaq dx2000MT RAM Replacement: adım 16, 3 resimden 3.
      • Remove the RAM by pulling it out towards the side of the device
      • Be careful about touching the top (right) and bottom (left)sides of the RAM! The static electricity in your fingers could short it. If you can, only touch the top and bottom of the RAM.
      • If replacing RAM, make sure it is the right type, speed, and size for your computer. Otherwise the RAM may not fit or your computer may not start up.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Logan Pace
2.414 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G16
4 Üyeler
120 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 54
Her zaman: 5,339
