Ana içeriğe geç
HP Compaq nc6400 Optical Drive Replacement
Neye ihtiyacın var
  1. HP Compaq nc6400 Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug laptop.
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq nc6400 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq nc6400 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq nc6400 Optical Drive Replacement: adım 4, 1 resimden 1.
    • Once both the battery locks are unlocked, slide the battery out to remove.
    FixBot'a Sor
    Yorum Ekle
  5. HP Compaq nc6400 Optical Drive Replacement, Optical Drive: adım 5, 2 resimden 1. HP Compaq nc6400 Optical Drive Replacement, Optical Drive: adım 5, 2 resimden 2.
    • Remove the 4 mm P0 Phillips-head screw indicated by the icon of a lock and disk.
    FixBot'a Sor
    Yorum Ekle
  6. HP Compaq nc6400 Optical Drive Replacement: adım 6, 2 resimden 1. HP Compaq nc6400 Optical Drive Replacement: adım 6, 2 resimden 2.
    • Press and release the eject icon to partially eject the optical drive.
    • Use of a spudger may be necessary to pry open the optical drive.
    FixBot'a Sor
    Yorum Ekle
  7. HP Compaq nc6400 Optical Drive Replacement: adım 7, 1 resimden 1.
    • Grasp the sides and pull the optical drive out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chad Williams
252 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G6
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 40
Her zaman: 5,067
