Ana içeriğe geç
HP Compaq nc6400 RAM Replacement
Neye ihtiyacın var
    1. HP Compaq nc6400 RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Turn off and unplug laptop.
      FixBot'a Sor
      Yorum Ekle
    2. HP Compaq nc6400 RAM Replacement: adım 2, 1 resimden 1.
      • Locate the battery lock below the battery labeled one.
      • Slide the lock all the way to the left to release the left lock of the battery.
      FixBot'a Sor
      Yorum Ekle
    3. HP Compaq nc6400 RAM Replacement: adım 3, 1 resimden 1.
      • Locate the lock labeled two at the bottom right corner below the battery.
      • Slide and hold the lock to the left.
      FixBot'a Sor
      Yorum Ekle
    4. HP Compaq nc6400 RAM Replacement: adım 4, 1 resimden 1.
      • Once both the battery locks are unlocked, slide the battery out to remove.
      FixBot'a Sor
      Yorum Ekle
    1. HP Compaq nc6400 RAM Replacement, RAM: adım 5, 2 resimden 1. HP Compaq nc6400 RAM Replacement, RAM: adım 5, 2 resimden 2.
      • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
      FixBot'a Sor
      Yorum Ekle
    2. HP Compaq nc6400 RAM Replacement: adım 6, 1 resimden 1.
      • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
      FixBot'a Sor
      Yorum Ekle
    3. HP Compaq nc6400 RAM Replacement: adım 7, 2 resimden 1. HP Compaq nc6400 RAM Replacement: adım 7, 2 resimden 2.
      • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
      • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
      FixBot'a Sor
      Yorum Ekle
    4. HP Compaq nc6400 RAM Replacement: adım 8, 1 resimden 1.
      • With a second plastic opening tool,repeat the above process
      • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
      FixBot'a Sor
      Yorum Ekle
    5. HP Compaq nc6400 RAM Replacement: adım 9, 2 resimden 1. HP Compaq nc6400 RAM Replacement: adım 9, 2 resimden 2.
      • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
      • Grab the RAM chip with your thumb and index finger
      • Carefully pull the RAM chip out
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Luis Vazquez
401 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G6
5 Üyeler
55 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 4,899
