Ana içeriğe geç
HP Compaq nc6400 Screen Replacement
Neye ihtiyacın var
  1. HP Compaq nc6400 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug laptop.
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq nc6400 Screen Replacement: adım 2, 1 resimden 1.
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq nc6400 Screen Replacement: adım 3, 1 resimden 1.
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq nc6400 Screen Replacement: adım 4, 1 resimden 1.
    • Once both the battery locks are unlocked, slide the battery out to remove.
    FixBot'a Sor
    Yorum Ekle
  5. HP Compaq nc6400 Screen Replacement, Screen: adım 5, 1 resimden 1.
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
    FixBot'a Sor
    Yorum Ekle
  6. HP Compaq nc6400 Screen Replacement: adım 6, 1 resimden 1.
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
    FixBot'a Sor
    Yorum Ekle
  7. HP Compaq nc6400 Screen Replacement: adım 7, 3 resimden 1. HP Compaq nc6400 Screen Replacement: adım 7, 3 resimden 2. HP Compaq nc6400 Screen Replacement: adım 7, 3 resimden 3.
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  8. HP Compaq nc6400 Screen Replacement: adım 8, 2 resimden 1. HP Compaq nc6400 Screen Replacement: adım 8, 2 resimden 2.
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
    FixBot'a Sor
    Yorum Ekle
  9. HP Compaq nc6400 Screen Replacement: adım 9, 1 resimden 1.
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
    FixBot'a Sor
    Yorum Ekle
  10. HP Compaq nc6400 Screen Replacement: adım 10, 2 resimden 1. HP Compaq nc6400 Screen Replacement: adım 10, 2 resimden 2.
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
    FixBot'a Sor
    Yorum Ekle
  11. HP Compaq nc6400 Screen Replacement: adım 11, 2 resimden 1. HP Compaq nc6400 Screen Replacement: adım 11, 2 resimden 2.
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
    FixBot'a Sor
    Yorum Ekle
  12. HP Compaq nc6400 Screen Replacement: adım 12, 2 resimden 1. HP Compaq nc6400 Screen Replacement: adım 12, 2 resimden 2.
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
    FixBot'a Sor
    Yorum Ekle
  13. HP Compaq nc6400 Screen Replacement: adım 13, 2 resimden 1. HP Compaq nc6400 Screen Replacement: adım 13, 2 resimden 2.
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Luis Vazquez
401 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G6
5 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Nicely done. Thanks?
Peter Q. - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 5,907
