Ana içeriğe geç
HP Compaq nc8430 LCD Screen Replacement
Neye ihtiyacın var
  1. HP Compaq nc8430 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq nc8430 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Slide up against the three lines the battery has.
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq nc8430 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq nc8430 LCD Screen Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Remove the four 1.2mm Phillip #1 screws circled.
    • The laptop may have rubber covers over the screws,. Remove them using a pointed tool to pry them out.
    FixBot'a Sor
    Yorum Ekle
  5. HP Compaq nc8430 LCD Screen Replacement: adım 5, 2 resimden 1. HP Compaq nc8430 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Pry up the plastic screen cover with the pry tool.
    • Once a corner of the plastic screen cover is lifted, slide the pry tool around the entire screen until the screen is completely lifted from the base.
    FixBot'a Sor
    Yorum Ekle
  6. HP Compaq nc8430 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Remove the 1.2 Phillips screws circled.
    FixBot'a Sor
    Yorum Ekle
  7. HP Compaq nc8430 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Remove the four 1.2mm Phillip screws circled.
    FixBot'a Sor
    Yorum Ekle
  8. HP Compaq nc8430 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Gently lift the monitor, from the base of the laptop.
    • The laptop will still be connected to the monitor wires located at the bottom of the screen.
    FixBot'a Sor
    Yorum Ekle
  9. HP Compaq nc8430 LCD Screen Replacement: adım 9, 2 resimden 1. HP Compaq nc8430 LCD Screen Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the video cable wires.
    • Gently remove the video cables from the sensor board with tweezers.
    FixBot'a Sor
    Yorum Ekle
  10. HP Compaq nc8430 LCD Screen Replacement: adım 10, 1 resimden 1.
    • All cables should be disconnected from the sensor board. Remove the eight 2mm Phillip screws attaching the bezel to the side of the monitor.
    • Attach the bezel to the new replacement screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
Texas Tech, Team S13-G4, Bennett Spring 2017 Texas Tech, Team S13-G4, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S13G4
5 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Could you please charge it using USB.
Cato Nicolai Lund - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 1,145
