Ana içeriğe geç
HP Compaq nc8430 RAM Replacement
Neye ihtiyacın var
  1. HP Compaq nc8430 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
    FixBot'a Sor
    Yorum Ekle
  2. HP Compaq nc8430 RAM Replacement: adım 2, 1 resimden 1.
    • Slide up against the three lines the battery has.
    FixBot'a Sor
    Yorum Ekle
  3. HP Compaq nc8430 RAM Replacement: adım 3, 1 resimden 1.
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
    FixBot'a Sor
    Yorum Ekle
  4. HP Compaq nc8430 RAM Replacement, Remove RAM cover: adım 4, 1 resimden 1.
    • Completely shut down the device and unplug any adapters and chords that are connected.
    FixBot'a Sor
    Yorum Ekle
  5. HP Compaq nc8430 RAM Replacement: adım 5, 1 resimden 1.
    • Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
    FixBot'a Sor
    Yorum Ekle
  6. HP Compaq nc8430 RAM Replacement, Locate RAM: adım 6, 1 resimden 1.
    • Locate the RAM after you remove the covering.
    FixBot'a Sor
    Yorum Ekle
  7. HP Compaq nc8430 RAM Replacement, Push clamps aside: adım 7, 1 resimden 1.
    • Use fingers or tools to press the clamps that hold the RAM in to the side.
    FixBot'a Sor
    Yorum Ekle
  8. HP Compaq nc8430 RAM Replacement, Pull RAM up to remove: adım 8, 1 resimden 1.
    • Place your fingers firmly on the RAM and pull it up.
    FixBot'a Sor
    Yorum Ekle
  9. HP Compaq nc8430 RAM Replacement, Remove RAM: adım 9, 1 resimden 1.
    • Place fingers firmly on RAM and pull it to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
bryan ingram
101 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
umm fine, except there is another module under the keyboard , rather an important fact to be overlooking
bari - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 1,082
