Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
A 9 year old Hewlett Packard nx7010 Business Notebook from 2004.
More specifically, its model number is Cnx7010RP745Y580Wcg25P
Back in 2004 it was a mid-range notebook priced at around A$2,000.
1.8GHz Intel Celeron single core CPU.
Windows XP Professional.
1680x1050 Anti-glare Screen (Which had a HORRIFIC ghosting effect).
A tour around the Notebook.
On the left hand side you will find a PCMCIA Card slot and the Optical drive.
On the right hand side you will find an Infra-Red window, Power jack, Kensington Lock and a fan vent.
On the back you will find VGA out, S-Video, 3x USB 2.0 ports, Phone line and Ethernet, Parallel port and FireWire (4 pin).
Here is the base of the notebook.
Product Number PQ803PA#ABG
Doors to access the battery, hard drive, RAM, CMOS battery, docking port and Mini PCI LAN network card.
Battery part number is [337607-001]
14.8 volts.
4.4 Amps per hour (4400 mAh).
8-cell.
The battery was advertised to last for 5 hours unplugged when it was new back in 2004.
After 9 years of cell deterioration, battery life is no more than 10 minutes.
Hard Disk Drive
Fujitsu MHT2080AH PL
80.0GB capacity
5,400 revolutions per minute
IDE Interface
Made in Thailand
S.M.A.R.T data reveals that this drive has been powered on for a total of 2 years
Mini PCI LAN Network card
Intel
Model Number [WM3B2200BG]
Wi-Fi Antennae plugs into this card
Hynix RAM from slot 1 under the base
512Mb SODIMM
333MHz
Model Number [512D16S1-6H-P]
CMOS battery
Maxell CR1220
3 Volts
Not very interesting
Removing the keyboard
Remove the two #0 Phillips screws from the base of the laptop
Turn the laptop over and open the lid
Undo the four clips at the top of the keyboard and flip out
Carefully undo the clip on the ribbon cable with a flat-head screw driver or spludger
Optical drive
Remove the single #0 Phillips screw
Slide out the optical drive
Model Number GWA-4080N
Manufactured with HP branding
Made in Korea in November 2004
DVD and CD compatable
RAM slot 2 located under the keyboard
It's another 512Mb DDR SODIMM made by Samsung
Product number [PC2700S-25331-A0]
Remove all 18 screws form the base and the rear.
14 screws from the base
4 screws from the rear
Removing the top panel between the keyboard and the screen reveals more screws to remove
4 screws remove the left speaker and fan shield
The three buttons in the speaker grille control the speakers
From top to bottom it goes Volume up, Volume down and Mute.
Remove a single screw and pry the connector for the screen from the motherboard.
After the connector is removed, the 1680x1050 15 inch (38cm) screen is free.
The display enclosure
It is actually quite easy to do a DIY screen replacement as there is no glass or adhesive to deal with but there are tabs that snap everything together
Removing the 6 screws allows you carefully remove the bezel by carefully undoing the tabs with a flathead screwdriver.
The hinges simply screw on and off
The 1680x1050 Cold Cathode Fluorescent back-lit (CCFL) display
Hitachi model number TX39D99VC1FAA
Separating the top from the bottom
Carefully remove both speaker, SD card, Touchpad and Bluetooth module plugs and de-route the cable that leads to the wireless module (not pictured)
After that you can lift to top from the base.
The Interior of the top panel
Contains the right hand speaker, Bluetooth module and Touchpad assembly
The Bluetooth module located above the battery or under the palmrest on the top right-hand side.
It is an Actiontec BTM200
The EMI shield for the optical drive and the touchpad
Removing it gives access to the Touchpad and mouse button daughter boards.
The metal frame bracket
It provides support for the notebook and makes it feel solid and rigid
Mouse and status LED daughter boards
The daughter board on top controsl the on/off mouse switch. The lower daughter board has status LED's, wireless on or off switch and headphone/microphone jacks
Left hand speaker
Model Number: FG-CP630
Product Number: PK230005610
1.5 watts of decent quality sound output.
The bare upper base.
All that is left that is not worth removing is an EMI shield and wireless network cable as well as the touchpad which is integrated into the upper base.
Now the best bit. The lower base
It contains the motherboard as well as all the other important components such as the graphics card and CPU.
First thing to be removed from the motherboard is the fan.
There are (currently) no screws securing the fan in place so removal is as simple as pulling it out.
The left hand speaker, metal frame and wireless communications.
The wireless (gray) cable attaches to the frame so the frame can act like an antenna.
The speaker has the model number PK230005710.
This speaker also provides 1.5 watts of sound output.
The SD card reader is located right at the front of the computer and it's screwed into the base with a single screw.
The model number is LS-1704.
Manufactured on 09/05/2003 (9th of May, 2003)
Next out is the CPU heat-sink.
It is held in with 4 sprung screws place around each corner of the CPU
And finally, the CPU
It's an Intel Celeron M 1.8GHz Single Core with 256k of cache.
55 million Processing Die Transistors
400MHz Front Side Bus (FSB)
Removal is as easy as turning the locking screw half a turn anti-clockwise to unlock and to then carefully lift up to remove.
The Modulator Demodulator (or Modem)
It is an Ambit Microsystems T60M283.11
Underneath an EMI shield (not pictured) we find the ATi Mobility Radeon 9200 graphics card.
64mb of dedicated graphical goodness
It is not integrated into the motherboard so if it fails it can replaced individually rather than having a whole motherboard or CPU replacement.
The removal of the motherboard.
Model Number A-1701 REV:2.0
Manufactured on the 9th of July, 2003
3 Yorum
Thanks, I found it most usefull :o)
Thanks! Very interesting. Maybe I clean the fan now. :-)
I didn’t have much luck with step 19, my top cover panel came out with the midframe after unscrewing all visible screws. But thanks anyway.
