Ana içeriğe geç
HP Deskjet 1000 J110a Parts Replacement
Neye ihtiyacın var
  1. HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: adım 1, 3 resimden 1. HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: adım 1, 3 resimden 2. HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: adım 1, 3 resimden 3.
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a  Parts Replacement: adım 2, 3 resimden 1. HP Deskjet 1000 J110a  Parts Replacement: adım 2, 3 resimden 2. HP Deskjet 1000 J110a  Parts Replacement: adım 2, 3 resimden 3.
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a  Parts Replacement: adım 3, 1 resimden 1.
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Colin Tourjee
632 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G3
4 Üyeler
12 adet Kılavuz yazıldı
2 Yorum
Very intuitive, good instructions. Highly recommended.
Krzysztof Białkowski - Yanıt
Thank you very much for the instructions on removing the cover to the HP 1200 Deskjet. It allowed me to removed a part that fell into the printer and prevented the paper from advancing.
karenliller@comcast.net - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 930
