Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
Bu adımda kullanılan alet:Tweezers$4.99-
Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
Locate and remove the three multicolored wire connectors which connect the circuit board to the other printer components.
Remove the top two 13mm screws using a screwdriver with the T10 torx bit.
Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
Bir başkası bu kılavuzu tamamladı.
