Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
Carefully hold the small clip back to release the button arm.
Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot.
Replace the old power button with a new one.
