Ana içeriğe geç
HP Deskjet 1055 Ink Cartridge Replacement
Neye ihtiyacın var
  1. HP Deskjet 1055 Ink Cartridge Replacement, Ink Cartridge: adım 1, 1 resimden 1.
    • Turn on the printer by pressing the power button.
  2. HP Deskjet 1055 Ink Cartridge Replacement: adım 2, 2 resimden 1. HP Deskjet 1055 Ink Cartridge Replacement: adım 2, 2 resimden 2.
    • Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
    • Pull down on the tab that lies in the middle of the newly-exposed gray cover.
  3. HP Deskjet 1055 Ink Cartridge Replacement: adım 3, 1 resimden 1.
    • The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • Grab the cartridge from the top and bottom and pull down until it clicks.
    • Pull out the freed cartridge.
  4. HP Deskjet 1055 Ink Cartridge Replacement: adım 4, 3 resimden 1. HP Deskjet 1055 Ink Cartridge Replacement: adım 4, 3 resimden 2. HP Deskjet 1055 Ink Cartridge Replacement: adım 4, 3 resimden 3.
    • Take the replacement cartridge out of its packaging and pull off the plastic tab.
    • Do not touch the electrical contacts or ink nozzles. Touching may cause malfunctions.
    • Hold the cartridge on both sides with the title sticker facing upwards.
  5. HP Deskjet 1055 Ink Cartridge Replacement: adım 5, 2 resimden 1. HP Deskjet 1055 Ink Cartridge Replacement: adım 5, 2 resimden 2.
    • Slide the cartridge directly into open slot (tri-color on the left, black on the right).
    • Push it forward until you hear it snap.
  6. HP Deskjet 1055 Ink Cartridge Replacement: adım 6, 1 resimden 1.
    • Close the gray access door.
  7. HP Deskjet 1055 Ink Cartridge Replacement: adım 7, 2 resimden 1. HP Deskjet 1055 Ink Cartridge Replacement: adım 7, 2 resimden 2.
    • Wait 30 seconds for the alignment page to print.
    • Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Close the lid.
  8. HP Deskjet 1055 Ink Cartridge Replacement: adım 8, 1 resimden 1.
    • Press the color copy button to begin scan.
    • Wait until the power button stops blinking.
Sonuç
When the power button stops blinking, your can now use your printer.
4 farklı kişi bu kılavuzu tamamladı.
Daniel
314 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G18
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 40
Her zaman: 16,225
