Ana içeriğe geç
HP Deskjet 1055 Motherboard Replacement
Neye ihtiyacın var
  1. HP Deskjet 1055 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. HP Deskjet 1055 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. HP Deskjet 1055 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Turn off the printer then open the top lid in order to see the inside of the printer.
    • Wait at least 15 minutes after turning off the printer before handling the motherboard.
    • After waiting 15 minutes, locate the blue tabs and gently pull them out of their sockets.
  2. HP Deskjet 1055 Motherboard Replacement: adım 2, 1 resimden 1.
    • Locate the three white plugs with wires attached to them. Gently grab the sides of the white chorded plugs and pull them out of their socket.
  3. HP Deskjet 1055 Motherboard Replacement: adım 3, 2 resimden 1. HP Deskjet 1055 Motherboard Replacement: adım 3, 2 resimden 2.
    • Using a T-10 Torx screwdriver, unscrew the three 1/2'' screws on the motherboard.
    • Note which screws were taken out of their specific spot because they must me placed back to their original spot.
  4. HP Deskjet 1055 Motherboard Replacement: adım 4, 1 resimden 1.
    • Carefully pull the motherboard out of the printer.
Sonuç
In order to reassemble your device, follow these instructions in reverse orders
7 farklı kişi bu kılavuzu tamamladı.
Daniel
314 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G18
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
How to open Top part
sunny.2600 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 5,434
