Ana içeriğe geç
HP Deskjet 2624 Motherboard Replacement
Neye ihtiyacın var
  1. HP Deskjet 2624 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Unplug all cords from the printer and remove the paper.
  2. HP Deskjet 2624 Motherboard Replacement: adım 2, 2 resimden 1. HP Deskjet 2624 Motherboard Replacement: adım 2, 2 resimden 2.
    • Using the Torx T5 screwdriver, remove the four screws connecting the scanner bed module to the printer base.
  3. HP Deskjet 2624 Motherboard Replacement: adım 3, 2 resimden 1. HP Deskjet 2624 Motherboard Replacement: adım 3, 2 resimden 2.
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the cables connected to the motherboard by gently pulling them straight out. Do not unplug the cables by pulling on the wires.
    • Unplug the last two ribbons connected to the motherboard by gently pulling them straight out.
    • Be sure to take note of where all plugs and ribbons are connected to the motherboard.
    • Remove the motherboard from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 497
