Ana içeriğe geç
HP Deskjet D1660 Encoder Strip Replacement
Neye ihtiyacın var
  1. HP Deskjet D1660 Encoder Strip Replacement, Encoder Strip: adım 1, 1 resimden 1.
    • Remove the back two 14.0 mm Torx #10 screws.
    FixBot'a Sor
    Yorum Ekle
  2. HP Deskjet D1660 Encoder Strip Replacement: adım 2, 1 resimden 1.
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
    FixBot'a Sor
    Yorum Ekle
  3. HP Deskjet D1660 Encoder Strip Replacement: adım 3, 1 resimden 1.
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
    FixBot'a Sor
    Yorum Ekle
  4. HP Deskjet D1660 Encoder Strip Replacement: adım 4, 3 resimden 1. HP Deskjet D1660 Encoder Strip Replacement: adım 4, 3 resimden 2. HP Deskjet D1660 Encoder Strip Replacement: adım 4, 3 resimden 3.
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
    FixBot'a Sor
    Yorum Ekle
  5. HP Deskjet D1660 Encoder Strip Replacement: adım 5, 3 resimden 1. HP Deskjet D1660 Encoder Strip Replacement: adım 5, 3 resimden 2. HP Deskjet D1660 Encoder Strip Replacement: adım 5, 3 resimden 3.
    • Looking at the printer from the front, carefully unhook the encoder strip from the left side.
    • Pull the strip to the left and push a little to unhook the strip.
    • Do the same thing on the other side by pulling to the right and pushing a little.
    • Pull the strip completely out from the cartridge holder.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Justin Taiki Fukada
912 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-41, Maness Winter 2014 Cal Poly, Team 1-41, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G41
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 74
Her zaman: 5,466
