Ana içeriğe geç
HP Deskjet D1660 Rollers Replacement
Neye ihtiyacın var
  1. HP Deskjet D1660 Rollers Replacement, Top Cover: adım 1, 1 resimden 1.
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Rollers Replacement: adım 2, 1 resimden 1.
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Rollers Replacement: adım 3, 1 resimden 1.
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Rollers Replacement: adım 4, 3 resimden 1. HP Deskjet D1660 Rollers Replacement: adım 4, 3 resimden 2. HP Deskjet D1660 Rollers Replacement: adım 4, 3 resimden 3.
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Rollers Replacement, Rollers: adım 5, 2 resimden 1. HP Deskjet D1660 Rollers Replacement, Rollers: adım 5, 2 resimden 2.
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  6. HP Deskjet D1660 Rollers Replacement: adım 6, 2 resimden 1. HP Deskjet D1660 Rollers Replacement: adım 6, 2 resimden 2.
    • Lift the cover up using both of your hands.
    • Lift it carefully as a strip and motor will be connected to the bottom part of the printer.
  7. HP Deskjet D1660 Rollers Replacement: adım 7, 2 resimden 1. HP Deskjet D1660 Rollers Replacement: adım 7, 2 resimden 2.
    • Locate the rollers, which will be on the bottom of the metal frame that holds the carriage.
    • Grab the rollers and remove them by pulling them to one side and lifting them up.
    • Do the same for the other three.
Sonuç
Justin Taiki Fukada
891 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-41, Maness Winter 2014 Cal Poly, Team 1-41, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G41
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,231
