Giriş
This guide will replace the springs located on the sides of the metal frame that holds the ink carriage. These springs provide stability to the metal rod that supports the ink cartridge carriage.
Neye ihtiyacın var
Remove the five 13.0 mm Torx #10 screws found on top of the frame.
Remove the four 9.0 mm Torx #10 smaller screws.
Locate the springs. They will be on the side of the metal frame.
Using the tweezers, grab the loop of the spring that is connected to the bar.
Remove the spring by lifting the loop.
Bir başkası bu kılavuzu tamamladı.
