Giriş
This step-by-step guide will show the user how to access, remove, and replace the paper-roller moter of an HP Deskjet F4480 printer. The paper-roller motor pulls paper into the printer and across the ink cartridges to ensure proper printing. If paper-feeding issues occur, replacing the paper-roller motor may be the solution. This task requires tools.
Neye ihtiyacın var
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Detach the white ribbon cable.
Remove the two 9mm Torx screws on either side of the white bracket.
To reassemble your device, with the addition of a new motor, follow these instructions in reverse order.
8 farklı kişi bu kılavuzu tamamladı.
