Ana içeriğe geç
HP ENVY 5530 Paper Tray Replacement
Neye ihtiyacın var
  1. HP ENVY 5530 Paper Tray Replacement, Paper Tray: adım 1, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement, Paper Tray: adım 1, 2 resimden 2.
    • Grab both sides of the printer and flip it away from you so the bottom is facing up.
  2. HP ENVY 5530 Paper Tray Replacement: adım 2, 1 resimden 1.
    • Locate the 13mm TR10 Torx screws on the left side of the paper tray.
  3. HP ENVY 5530 Paper Tray Replacement: adım 3, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 3, 2 resimden 2.
    • Unscrew and remove the 13mm TR10 Torx Security screw, starting with the farthest screw on the left
  4. HP ENVY 5530 Paper Tray Replacement: adım 4, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 4, 2 resimden 2.
    • Locate and remove middle 13mm TR10 Torx Security screw using a Torx screwdriver.
  5. HP ENVY 5530 Paper Tray Replacement: adım 5, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 5, 2 resimden 2.
    • Locate and remove the last 13mm TR10 Torx Security screw.
  6. HP ENVY 5530 Paper Tray Replacement: adım 6, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 6, 2 resimden 2.
    • Locate the side tab and lift up to remove.
  7. HP ENVY 5530 Paper Tray Replacement: adım 7, 1 resimden 1.
    • Locate the three 13mm TR10 Torx Security screws on the right side panel.
  8. HP ENVY 5530 Paper Tray Replacement: adım 8, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 8, 2 resimden 2.
    • Locate and remove the farthest 13mm TR10 Torx Security screw.
  9. HP ENVY 5530 Paper Tray Replacement: adım 9, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 9, 2 resimden 2.
    • Locate middle 13mm TR10 Torx Security screw and remove it.
  10. HP ENVY 5530 Paper Tray Replacement: adım 10, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 10, 2 resimden 2.
    • Locate last 13mm TR10 Torx Security screw and remove it.
  11. HP ENVY 5530 Paper Tray Replacement: adım 11, 2 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 11, 2 resimden 2.
    • Locate tab on the right side panel and lift to remove it.
  12. HP ENVY 5530 Paper Tray Replacement: adım 12, 1 resimden 1.
    • The back should look like this.
  13. HP ENVY 5530 Paper Tray Replacement: adım 13, 3 resimden 1. HP ENVY 5530 Paper Tray Replacement: adım 13, 3 resimden 2. HP ENVY 5530 Paper Tray Replacement: adım 13, 3 resimden 3.
    • Remove paper tray by pulling it out and away from the printer.
    • Be cautious of jumping springs once pulling out the paper tray.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elizabeth Surface
1.465 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G6
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 2,508
