Ana içeriğe geç
HP ENVY 5530 Power Supply Replacement
Neye ihtiyacın var
  1. HP ENVY 5530 Power Supply Replacement, AC Adaptor: adım 1, 3 resimden 1. HP ENVY 5530 Power Supply Replacement, AC Adaptor: adım 1, 3 resimden 2. HP ENVY 5530 Power Supply Replacement, AC Adaptor: adım 1, 3 resimden 3.
    • Open the the printer by lifting the top section. Make sure you're lifting from the lowest portion of the scanner section.
  2. HP ENVY 5530 Power Supply Replacement: adım 2, 3 resimden 1. HP ENVY 5530 Power Supply Replacement: adım 2, 3 resimden 2. HP ENVY 5530 Power Supply Replacement: adım 2, 3 resimden 3.
    • Locate 13mm TR10 Torx Security screw behind screen and remove using Torx screwdriver.
  3. HP ENVY 5530 Power Supply Replacement: adım 3, 3 resimden 1. HP ENVY 5530 Power Supply Replacement: adım 3, 3 resimden 2. HP ENVY 5530 Power Supply Replacement: adım 3, 3 resimden 3.
    • Remove case covering by lifting it up to reveal the power cord.
  4. HP ENVY 5530 Power Supply Replacement: adım 4, 2 resimden 1. HP ENVY 5530 Power Supply Replacement: adım 4, 2 resimden 2.
    • Locate power cord.
    • Pull it out.
  5. HP ENVY 5530 Power Supply Replacement: adım 5, 2 resimden 1. HP ENVY 5530 Power Supply Replacement: adım 5, 2 resimden 2.
    • Locate 13mm TR10 Torx Security screw behind screen and remove with screwdriver.
  6. HP ENVY 5530 Power Supply Replacement: adım 6, 2 resimden 1. HP ENVY 5530 Power Supply Replacement: adım 6, 2 resimden 2.
    • Use a metal spudger around the edge to remove AC adapter cover.
  7. HP ENVY 5530 Power Supply Replacement: adım 7, 1 resimden 1.
    • Pull the AC adaptor up and out of its casing
  8. HP ENVY 5530 Power Supply Replacement: adım 8, 3 resimden 1. HP ENVY 5530 Power Supply Replacement: adım 8, 3 resimden 2. HP ENVY 5530 Power Supply Replacement: adım 8, 3 resimden 3.
    • Disconnect the wires from the AC adaptor.
    • Replace AC Adapter box. Reverse order of instructions for reassembly.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Justin
295 İtibar
1 Kılavuz yazıldı
Ekip
USF-Leahy-S18S1G1 USF-Leahy-S18S1G1 üyesi
Community
3 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 57
Her zaman: 1,859
