Giriş
Use the plastic opening tool as much as possible when removing the back cover to prevent damaging it. The USB board is fairly easy to replace however use care when un-plugging and re-plugging the blue 16 pin plug connecting the USB to the motherboard in steps 10 and 11.
Replacing the USB board is a last resort solution for a malfunctioning USB port. Check out the trouble shooting page of this guide before jumping immediately to part replacement.
Neye ihtiyacın var
Flip up the white plastic that holds the cable connection using the plastic opening tool.
Bir başkası bu kılavuzu tamamladı.
