Ana içeriğe geç
HP Elite X2 1013 G3 Solid State Drive Replacement
Neye ihtiyacın var
  1. HP Elite X2 1013 G3 Solid State Drive Replacement, Screen: adım 1, 1 resimden 1.
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Solid State Drive Replacement: adım 2, 2 resimden 1. HP Elite X2 1013 G3 Solid State Drive Replacement: adım 2, 2 resimden 2.
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Solid State Drive Replacement: adım 3, 2 resimden 1. HP Elite X2 1013 G3 Solid State Drive Replacement: adım 3, 2 resimden 2.
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Solid State Drive Replacement: adım 4, 2 resimden 1. HP Elite X2 1013 G3 Solid State Drive Replacement: adım 4, 2 resimden 2.
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Solid State Drive Replacement, Battery: adım 5, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Solid State Drive Replacement: adım 6, 1 resimden 1.
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Solid State Drive Replacement, Solid State Drive: adım 7, 1 resimden 1.
    • Make sure the device is powered off and the battery is removed before continuing!
    • Using the Phillips #00 Screwdriver, remove the single indicated screw.
  8. HP Elite X2 1013 G3 Solid State Drive Replacement: adım 8, 1 resimden 1.
    • Gently tilt the drive upward, then firmly pull it out from the motherboard.
    • Pay attention to the orientation of the SSD. Trying to put your replacement SSD in the wrong way could damage the part or the connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kory Haydon
259 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G12, Maness Spring 2019 Cal Poly, Team S9-G12, Maness Spring 2019 üyesi
CPSU-MANESS-S19S9G12
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 68
Her zaman: 2,732
