Ana içeriğe geç
HP Elite X2 G4 Display Assembly Replacement
Neye ihtiyacın var
  1. HP Elite X2 G4 Display Assembly Replacement, Display Assembly: adım 1, 1 resimden 1.
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite X2 G4 Display Assembly Replacement: adım 2, 1 resimden 1.
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite X2 G4 Display Assembly Replacement: adım 3, 1 resimden 1.
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite X2 G4 Display Assembly Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite X2 G4 Display Assembly Replacement: adım 5, 1 resimden 1.
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Goncalo Felix
325 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G4
5 Üyeler
Bir Yorum
Boa tarde Gonçalo.
Sabe dizer-me onde posso comprar um ecrã original para o meu HP Elite X2 G4?
Obrigado
Pedro Santos
Pedro_Neno - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 564
