Ana içeriğe geç
HP Elite x2 1012 G2 Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Elite x2 1012 G2 Cooling Fan Replacement, Screen: adım 1, 1 resimden 1.
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 2, 3 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 2, 3 resimden 2. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 3, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 5, 3 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 5, 3 resimden 2. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 6, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Cooling Fan Replacement, Battery: adım 7, 1 resimden 1.
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 8, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 8, 2 resimden 2.
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 9, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 9, 2 resimden 2.
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 10, 1 resimden 1.
    • Lift the battery out of the device.
  11. HP Elite x2 1012 G2 Cooling Fan Replacement, Cooling Fan: adım 11, 1 resimden 1.
    • Use the spudger tools to lift the copper tape and expose the screws.
  12. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 12, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 12, 2 resimden 2.
    • Use Phillips #00 screwdriver to remove seven 3 mm screws.
  13. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 13, 1 resimden 1.
    • Lift the heatsink off the motherboard.
  14. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 14, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the final two 3 mm screws that secure the fan.
  15. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 15, 1 resimden 1.
    • Use a spudger to lift the fan from the main unit.
  16. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 16, 1 resimden 1.
    • Use a spudger to lift the connection for the fan and disconnect the plug from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
WesleyEagleson
431 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S13G13
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 61
Her zaman: 2,410
