Ana içeriğe geç
HP Elite x2 1012 G2 Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Elite x2 1012 G2 Cooling Fan Replacement, Screen: adım 1, 1 resimden 1.
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 2, 3 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 2, 3 resimden 2. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 3, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 5, 3 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 5, 3 resimden 2. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 6, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Cooling Fan Replacement, Battery: adım 7, 1 resimden 1.
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 8, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 8, 2 resimden 2.
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 9, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 9, 2 resimden 2.
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 10, 1 resimden 1.
    • Lift the battery out of the device.
  11. HP Elite x2 1012 G2 Cooling Fan Replacement, Cooling Fan: adım 11, 1 resimden 1.
    • Use the spudger tools to lift the copper tape and expose the screws.
  12. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 12, 2 resimden 1. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 12, 2 resimden 2.
    • Use Phillips #00 screwdriver to remove seven 3 mm screws.
  13. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 13, 1 resimden 1.
    • Lift the heatsink off the motherboard.
  14. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 14, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the final two 3 mm screws that secure the fan.
  15. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 15, 1 resimden 1.
    • Use a spudger to lift the fan from the main unit.
  16. HP Elite x2 1012 G2 Cooling Fan Replacement: adım 16, 1 resimden 1.
    • Use a spudger to lift the connection for the fan and disconnect the plug from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
WesleyEagleson
431 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S13G13
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 2,818
