Ana içeriğe geç
HP Elite x2 1012 G2 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Screen: adım 1, 1 resimden 1.
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 2, 3 resimden 1. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 2, 3 resimden 2. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 2, 3 resimden 3.
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 3, 2 resimden 1. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 3, 2 resimden 2.
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 4, 1 resimden 1.
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 5, 3 resimden 1. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 5, 3 resimden 2. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 5, 3 resimden 3.
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 6, 2 resimden 1. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 6, 2 resimden 2.
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: adım 7, 2 resimden 1. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: adım 7, 2 resimden 2.
    • Locate the cameras at the top center of the power and processing unit.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw.
    • Use a spudger tool to lift up the ribbon cable clamps.
    • Be careful not to crease or damage the ribbon cables or connectors.
  8. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 8, 2 resimden 1. HP Elite x2 1012 G2 Rear Facing Camera Replacement: adım 8, 2 resimden 2.
    • Remove the front-facing camera.
    • Remove the metal bracket securing the rear-facing camera.
    • Remove the rear-facing camera.
Sonuç
WesleyEagleson
431 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S13G13
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 537
