Ana içeriğe geç
HP Elite x2 1012 G2 Screen Replacement
Neye ihtiyacın var
  1. HP Elite x2 1012 G2 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Screen Replacement: adım 2, 3 resimden 1. HP Elite x2 1012 G2 Screen Replacement: adım 2, 3 resimden 2. HP Elite x2 1012 G2 Screen Replacement: adım 2, 3 resimden 3.
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Screen Replacement: adım 3, 2 resimden 1. HP Elite x2 1012 G2 Screen Replacement: adım 3, 2 resimden 2.
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Screen Replacement: adım 4, 1 resimden 1.
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Screen Replacement: adım 5, 3 resimden 1. HP Elite x2 1012 G2 Screen Replacement: adım 5, 3 resimden 2. HP Elite x2 1012 G2 Screen Replacement: adım 5, 3 resimden 3.
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Screen Replacement: adım 6, 2 resimden 1. HP Elite x2 1012 G2 Screen Replacement: adım 6, 2 resimden 2.
    • Remove the screen by gently lifting it off of the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Noah Stapp
767 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S18G5
4 Üyeler
13 adet Kılavuz yazıldı
5 Yorum
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - Yanıt
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - Yanıt
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - Yanıt
The touch stopped working after the replacement. Any suggestions?
el._.msn - Yanıt
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 22
Son 30 gün: 126
Her zaman: 8,733
