Ana içeriğe geç
HP Elite x2 1012 G2 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Screen: adım 1, 1 resimden 1.
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 2, 3 resimden 1. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 2, 3 resimden 2. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 3, 2 resimden 1. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 5, 3 resimden 1. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 5, 3 resimden 2. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 5, 3 resimden 3.
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 6, 2 resimden 1. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 6, 2 resimden 2.
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Wi-Fi Card: adım 7, 1 resimden 1.
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 8, 3 resimden 1. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 8, 3 resimden 2. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 8, 3 resimden 3.
    • Detach the two wire connections on the upper right of the wi-fi card by hand.
  9. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 9, 2 resimden 1. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 9, 2 resimden 2.
    • Use a Phillips 2mm screwdriver to remove the single M2 2.0x2.0 screw holding the wi-fi card in place. Turn the screwdriver counterclockwise to remove the screw.
  10. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 10, 2 resimden 1. HP Elite x2 1012 G2 Wi-Fi Card Replacement: adım 10, 2 resimden 2.
    • Slide the wi-fi card out by hand, lifting the card up and out of the device.
    • If it doesn't come out immediately, slowly wiggle the card side to side until it slides out of its connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nathan Diekema
321 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S18G5
4 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
Hi is it to upgrade the broadband to support 4g lte? Mine unit when inserted 4g data sim card, only can run edge signal. Spec of the broadband is hp hs3210 hspa+
Kenny Liew - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 2,545
