Ana içeriğe geç
HP Elite x2 G1 1012 Display Replacement
Neye ihtiyacın var
  1. HP Elite x2 G1 1012 Display Replacement, Display: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Display Replacement: adım 2, 2 resimden 1. HP Elite x2 G1 1012 Display Replacement: adım 2, 2 resimden 2.
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Display Replacement: adım 3, 1 resimden 1.
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Display Replacement: adım 4, 2 resimden 1. HP Elite x2 G1 1012 Display Replacement: adım 4, 2 resimden 2.
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Display Replacement: adım 5, 3 resimden 1. HP Elite x2 G1 1012 Display Replacement: adım 5, 3 resimden 2. HP Elite x2 G1 1012 Display Replacement: adım 5, 3 resimden 3.
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Display Replacement: adım 6, 2 resimden 1. HP Elite x2 G1 1012 Display Replacement: adım 6, 2 resimden 2.
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Colin Mika
943 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G7, Maness Spring 2018 Cal Poly, Team S24-G7, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G7
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 3,283
