Ana içeriğe geç
HP Elite x2 G1 1012 Motherboard Replacement Guide
Neye ihtiyacın var
  1. HP Elite x2 G1 1012 Motherboard Replacement Guide, Motherboard: adım 1, 2 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide, Motherboard: adım 1, 2 resimden 2.
    • Detach the keyboard from the screen.
  2. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 2, 1 resimden 1.
    • While the screen is facing down, remove six 3.0 mm Torx T5 screws under the stand.
    • The screws were not available when we received our device.
  3. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 3, 3 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 3, 3 resimden 2. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 3, 3 resimden 3.
    • Use a suction cup to remove the screen panel.
  4. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 4, 3 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 4, 3 resimden 2. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 4, 3 resimden 3.
    • Detach flex cable from motherboard using tweezers.
  5. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 5, 1 resimden 1.
    • Unplug the battery wire attached to the motherboard using tweezers.
  6. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 6, 3 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 6, 3 resimden 2. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 6, 3 resimden 3.
    • Remove ten 2.7mm screws using the Phillips #0 screwdriver.
  7. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 7, 2 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 7, 2 resimden 2.
    • Unplug the speaker wire attached to the motherboard.
  8. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 8, 2 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 8, 2 resimden 2.
    • Detach the left speaker.
  9. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 9, 2 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 9, 2 resimden 2.
    • Detach the two stickers highlighted from the right speaker.
  10. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 10, 1 resimden 1.
    • Detach the right speaker cables from the motherboard using tweezers.
  11. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 11, 2 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 11, 2 resimden 2.
    • Detach the right speaker.
  12. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 12, 1 resimden 1.
    • Detach the WWAN card from the motherboard by pulling it to the left using tweezers.
  13. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 13, 1 resimden 1.
    • Detach the SSD from motherboard by pulling it to the left using tweezers.
  14. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 14, 1 resimden 1.
    • Use the plastic opening tool to loosen the motherboard.
  15. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 15, 3 resimden 1. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 15, 3 resimden 2. HP Elite x2 G1 1012 Motherboard Replacement Guide: adım 15, 3 resimden 3.
    • Detach the motherboard from the casing.
    • Apply pulling force to the left to pull out the ports from the casing safely.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Hanif Norhisham
564 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Harley Summer 2019 IUPUI, Team S1-G5, Harley Summer 2019 üyesi
IUPUI-HARLEY-SU19S1G5
4 Üyeler
Bir Yorum
¿basta con esto para cambiar el cable LCD?
Is this enough to replace the LCD wire?
Pablo Sánchez-Simón - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 3,147
