Ana içeriğe geç
HP Elite x2 G4 Battery Replacement
Neye ihtiyacın var
  1. HP Elite x2 G4 Battery Replacement, Display Assembly: adım 1, 1 resimden 1.
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Battery Replacement: adım 2, 1 resimden 1.
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Battery Replacement: adım 3, 1 resimden 1.
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Battery Replacement, Battery: adım 6, 1 resimden 1.
    • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
  7. HP Elite x2 G4 Battery Replacement: adım 7, 1 resimden 1.
    • Carefully lift the top edge of the battery off of the alignment pins.
    • Remove the battery.
  8. HP Elite x2 G4 Battery Replacement: adım 8, 1 resimden 1.
    • Slide the bottom edge out from retention tabs on the display enclosure and remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Goncalo Felix
325 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G4
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 142
Her zaman: 1,228
