Giriş
One of the primary reasons to upgrade your motherboard is a new, faster CPU, or if your current motherboard is damaged. This guide will help you replace your HP Elite x2 G4 motherboard. To begin the process, we recommend watching this video.
This guide contains step by step instructions to complete the installation. There are no special skills required to complete this replacement. There are only two tools needed for installation a T5 Torx Screwdriver, and a Phillips #0 Screwdriver. The following are hazards that should be avoided during installation:
Short circuit: Ensure that all cables are securely connected, screws are tightened, and the motherboard is properly fitted into the case.
Physical Damage: Mishandling during installation can cause physical damage to the motherboard. Avoid bending pins, damaging ports, or placing the motherboard in contact with unintended objects.
Neye ihtiyacın var
Open the kickstand.
Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
Remove the two 2.5 mm Phillips #0 screws that secure the USB bracket to the motherboard.
Bir başkası bu kılavuzu tamamladı.
