Ana içeriğe geç
HP EliteBook 1040 G4 Display Replacement
Neye ihtiyacın var
  1. HP EliteBook 1040 G4 Display Replacement, Display: adım 1, 1 resimden 1.
    • Wedge an opening tool between the display and the chassis, gently prying around the perimeter until the display completely releases.
  2. HP EliteBook 1040 G4 Display Replacement: adım 2, 2 resimden 1. HP EliteBook 1040 G4 Display Replacement: adım 2, 2 resimden 2.
    • Lift the metal arm, then pull the display ribbon cable directly out of its port.
  3. HP EliteBook 1040 G4 Display Replacement: adım 3, 2 resimden 1. HP EliteBook 1040 G4 Display Replacement: adım 3, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  4. HP EliteBook 1040 G4 Display Replacement: adım 4, 1 resimden 1.
    • Remove the hinge cover.
  5. HP EliteBook 1040 G4 Display Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 5 mm black screws that securing the dispaly.
  6. HP EliteBook 1040 G4 Display Replacement: adım 6, 2 resimden 1. HP EliteBook 1040 G4 Display Replacement: adım 6, 2 resimden 2.
    • Lift the display up and out of its housing.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 1,222
