Ana içeriğe geç
HP EliteBook 1040 G4 Fan Replacement
Neye ihtiyacın var
  1. HP EliteBook 1040 G4 Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Fan Replacement: adım 2, 2 resimden 1. HP EliteBook 1040 G4 Fan Replacement: adım 2, 2 resimden 2.
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Fan Replacement, Fan: adım 3, 2 resimden 1. HP EliteBook 1040 G4 Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the two silver 5 mm screws surrounding the fan.
    • The top left screw may be hidden under shielding tape.
  4. HP EliteBook 1040 G4 Fan Replacement: adım 4, 3 resimden 1. HP EliteBook 1040 G4 Fan Replacement: adım 4, 3 resimden 2. HP EliteBook 1040 G4 Fan Replacement: adım 4, 3 resimden 3.
    • Remove the electrical tape to expose the heat sink screws.
    • Using the Phillips #0 screwdriver, unscrew the four screws securing the heatsink to the motherboard.
    • Carefully disconnect the pin connector by pulling it from its slot.
  5. HP EliteBook 1040 G4 Fan Replacement: adım 5, 1 resimden 1.
    • Carefully remove the wires from the clip to the left of the fan.
  6. HP EliteBook 1040 G4 Fan Replacement: adım 6, 2 resimden 1. HP EliteBook 1040 G4 Fan Replacement: adım 6, 2 resimden 2.
    • Lift and remove the fan and heatsink assembly from the device.
Sonuç
Hannah DiMartino
395 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-1, Hunter Fall 2021 Clemson, Team 4-1, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G1
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 794
