Ana içeriğe geç
HP EliteBook 1040 G4 Motherboard Replacement
Neye ihtiyacın var
  1. HP EliteBook 1040 G4 Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Motherboard Replacement: adım 2, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 2, 2 resimden 2.
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Motherboard Replacement: adım 4, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Motherboard Replacement: adım 5, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 5, 2 resimden 2.
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Motherboard Replacement, SSD: adım 6, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the single 5 mm screw securing the SSD to the motherboard.
  7. HP EliteBook 1040 G4 Motherboard Replacement: adım 7, 1 resimden 1.
    • Lift the SSD up and out of the device.
  8. HP EliteBook 1040 G4 Motherboard Replacement, Fan: adım 8, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement, Fan: adım 8, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the two silver 5 mm screws surrounding the fan.
    • The top left screw may be hidden under shielding tape.
  9. HP EliteBook 1040 G4 Motherboard Replacement: adım 9, 3 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 9, 3 resimden 2. HP EliteBook 1040 G4 Motherboard Replacement: adım 9, 3 resimden 3.
    • Remove the electrical tape to expose the heat sink screws.
    • Using the Phillips #0 screwdriver, unscrew the four screws securing the heatsink to the motherboard.
    • Carefully disconnect the pin connector by pulling it from its slot.
  10. HP EliteBook 1040 G4 Motherboard Replacement: adım 10, 1 resimden 1.
    • Carefully remove the wires from the clip to the left of the fan.
  11. HP EliteBook 1040 G4 Motherboard Replacement: adım 11, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 11, 2 resimden 2.
    • Lift and remove the fan and heatsink assembly from the device.
  12. HP EliteBook 1040 G4 Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the five black 4 mm screws securing the motherboard to the device.
  13. HP EliteBook 1040 G4 Motherboard Replacement: adım 13, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 13, 2 resimden 2.
    • Using the same Phillips #0 screwdriver, remove the two silver 6.5 mm screws from the secondary fan placeholder.
    • Remove the fan placeholder from the device.
  14. HP EliteBook 1040 G4 Motherboard Replacement: adım 14, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 14, 2 resimden 2.
    • Carefully disonnect the "Main" and "Aux" cables from the dual band wireless driver.
  15. HP EliteBook 1040 G4 Motherboard Replacement: adım 15, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 15, 2 resimden 2.
    • Remove the ZIF connector from the bottom left of the motherboard by lifting the small grey tab, then pulling the connector out of the slot.
    • For more information on properly disconnecting and removing Zero Insertion Force (ZIF) connectors, please visit this guide.
  16. HP EliteBook 1040 G4 Motherboard Replacement: adım 16, 1 resimden 1.
    • Disconnect and remove the four ZIF connectors from the bottom middle of the motherboard by lifting the small locking tabs, then pulling the connectors out of their slots.
  17. HP EliteBook 1040 G4 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the pin connector from the top right corner of the motherboard.
  18. HP EliteBook 1040 G4 Motherboard Replacement: adım 18, 1 resimden 1.
    • Remove the ZIF connector from the top right corner of the motherboard by lifting the locking tab, then pulling the connector out of the slot.
  19. HP EliteBook 1040 G4 Motherboard Replacement: adım 19, 2 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 19, 2 resimden 2.
    • Remove the pin connectors in the top right corner of the motherboard by lifting them straight up. The longer, top, connector has a pull tab connected to it to assist in pulling it out.
  20. HP EliteBook 1040 G4 Motherboard Replacement: adım 20, 3 resimden 1. HP EliteBook 1040 G4 Motherboard Replacement: adım 20, 3 resimden 2. HP EliteBook 1040 G4 Motherboard Replacement: adım 20, 3 resimden 3.
    • Remove the RTC battery pin connector from the underside of the motheroard.
  21. HP EliteBook 1040 G4 Motherboard Replacement: adım 21, 1 resimden 1.
    • Carefully lift and remove the motherboard.
Sonuç
Ryan Cameron
181 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 4-1, Hunter Fall 2021 Clemson, Team 4-1, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G1
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 43
Her zaman: 1,319
