Ana içeriğe geç
HP EliteBook 1040 G4 Speakers Replacement
Neye ihtiyacın var
  1. HP EliteBook 1040 G4 Speakers Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Speakers Replacement: adım 2, 2 resimden 1. HP EliteBook 1040 G4 Speakers Replacement: adım 2, 2 resimden 2.
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Speakers Replacement, Battery: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Speakers Replacement: adım 4, 2 resimden 1. HP EliteBook 1040 G4 Speakers Replacement: adım 4, 2 resimden 2.
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Speakers Replacement: adım 5, 2 resimden 1. HP EliteBook 1040 G4 Speakers Replacement: adım 5, 2 resimden 2.
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Speakers Replacement, Speakers: adım 6, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the four black 6 mm screws securing the speakers to the device.
  7. HP EliteBook 1040 G4 Speakers Replacement: adım 7, 1 resimden 1.
    • Disconnect the pin connector from the right side of the speaker assembly.
  8. HP EliteBook 1040 G4 Speakers Replacement: adım 8, 1 resimden 1.
    • Carefully remove the red and black wires from the black clips in between the two speakers.
  9. HP EliteBook 1040 G4 Speakers Replacement: adım 9, 1 resimden 1.
    • Remove the speakers from the device.
Sonuç
Hannah DiMartino
395 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-1, Hunter Fall 2021 Clemson, Team 4-1, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G1
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 655
