Ana içeriğe geç
HP EliteBook 1040 G4 Trackpad Replacement
Neye ihtiyacın var
  1. HP EliteBook 1040 G4 Trackpad Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Trackpad Replacement: adım 2, 2 resimden 1. HP EliteBook 1040 G4 Trackpad Replacement: adım 2, 2 resimden 2.
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Trackpad Replacement, Battery: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Trackpad Replacement: adım 4, 2 resimden 1. HP EliteBook 1040 G4 Trackpad Replacement: adım 4, 2 resimden 2.
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Trackpad Replacement: adım 5, 2 resimden 1. HP EliteBook 1040 G4 Trackpad Replacement: adım 5, 2 resimden 2.
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Trackpad Replacement, Trackpad: adım 6, 1 resimden 1.
    • Peel back the foam cover to reveal the underside of the trackpad.
  7. HP EliteBook 1040 G4 Trackpad Replacement: adım 7, 1 resimden 1.
    • Carefully disconnect the white ribbon cable attached to the underside of the trackpad.
  8. HP EliteBook 1040 G4 Trackpad Replacement: adım 8, 1 resimden 1.
    • Carefully disconnect the black ribbon cable attached to the chassis.
  9. HP EliteBook 1040 G4 Trackpad Replacement: adım 9, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws securing the trackpad.
  10. HP EliteBook 1040 G4 Trackpad Replacement: adım 10, 1 resimden 1.
    • Lift and remove the trackpad from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 432
