Ana içeriğe geç
HP EliteBook 645 G10 Thermal Paste Replacement
Neye ihtiyacın var
  1. HP EliteBook 645 G10 Thermal Paste Replacement, Opening the back panel.: adım 1, 3 resimden 1. HP EliteBook 645 G10 Thermal Paste Replacement, Opening the back panel.: adım 1, 3 resimden 2. HP EliteBook 645 G10 Thermal Paste Replacement, Opening the back panel.: adım 1, 3 resimden 3.
    • Remove the 5 screws holding the back panel.
    • Use a prying tool to carefully release all the clips holding the panel in place.
  2. HP EliteBook 645 G10 Thermal Paste Replacement, Replacing the old thermal paste.: adım 2, 2 resimden 1. HP EliteBook 645 G10 Thermal Paste Replacement, Replacing the old thermal paste.: adım 2, 2 resimden 2.
    • Unscrew the 4 screws holding the CPU heatsink and lift it up, gently.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • Don`t use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure.
  3. HP EliteBook 645 G10 Thermal Paste Replacement, Upgrading the RAM and SSD (Optional): adım 3, 1 resimden 1.
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Simeon Brankov
7.279 İtibar
54 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 33
Son 30 gün: 322
Her zaman: 1,709
