Ana içeriğe geç
HP EliteBook 745 G2 RAM Chip Replacement
Neye ihtiyacın var
    1. HP EliteBook 745 G2 RAM Chip Replacement, Battery: adım 1, 1 resimden 1.
      • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
      FixBot'a Sor
      Yorum Ekle
    2. HP EliteBook 745 G2 RAM Chip Replacement: adım 2, 2 resimden 1. HP EliteBook 745 G2 RAM Chip Replacement: adım 2, 2 resimden 2.
      • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. HP EliteBook 745 G2 RAM Chip Replacement: adım 3, 2 resimden 1. HP EliteBook 745 G2 RAM Chip Replacement: adım 3, 2 resimden 2.
      • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
      FixBot'a Sor
      Yorum Ekle
    1. HP EliteBook 745 G2 RAM Chip Replacement, RAM Chip: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      Anti-Static Wrist Strap
      $7.95
      FixBot'a Sor
      Yorum Ekle
    2. HP EliteBook 745 G2 RAM Chip Replacement: adım 5, 1 resimden 1.
      • Using the spudger, gently press down on the tabs holding the chip to release it. Repeat this step for the other chip.
      FixBot'a Sor
      Yorum Ekle
    3. HP EliteBook 745 G2 RAM Chip Replacement: adım 6, 1 resimden 1.
      • Grab the chip and lift it away from the laptop at a 45 degree angle.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 816
