Ana içeriğe geç
HP EliteBook 745 G4 Battery Replacement
Neye ihtiyacın var
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: adım 2, 1 resimden 1.
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: adım 3, 2 resimden 1. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: adım 3, 2 resimden 2.
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: adım 4, 1 resimden 1.
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: adım 5, 1 resimden 1.
    • Loosen the two captive screws and remove the battery from the computer
Sonuç
To replace the battery & reassemble your device, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Max Kletskov
40.418 İtibar
16 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.085 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 45
Her zaman: 1,298
