Giriş
Adding more memory is the best thing you can do for your PC. The larger memory can provide an instant upgrade for the system. By following this repair guide, you could add or upgrade the memory in HP EliteBook 745 G6 Notebook by yourself.
You need to pay attention to remove power, disconnect batteries, and use an anti-static wrist strap during the repair process. This is a video for how to use an anti-static wrist strap.
The device & model of this repair guide is HP EliteBook 745 G6 Notebook. For more information on this device, refer to the maintenance and service manual.
Neye ihtiyacın var
Type CMD in the Start Menu and open Command Prompt.
Type the following command to view memory details and press Enter.
Turn the notebook upside down on a flat surface.
Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
Pry the bottom cover with plastic card or spudger at the bottom right corner.
Lift the bottom cover off with plastic card.
wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor
Right-click on the taskbar.
Select the “Task Manager”.
Select the "Performance".
Bir başkası bu kılavuzu tamamladı.
