Ana içeriğe geç
HP EliteBook 755 G5 Battery Replacement
Neye ihtiyacın var
    • Turn off the computer. If you are unsure whether the computer is in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: adım 2, 2 resimden 1. HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: adım 2, 2 resimden 2.
    • Turn the computer upside down on a flat surface.
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
    • Starting under the middle of the display, pry and lift the bottom cover off the computer.
  2. HP EliteBook 755 G5 Battery Replacement, Disconnect the battery: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  3. HP EliteBook 755 G5 Battery Replacement, Remove the battery: adım 4, 1 resimden 1.
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
Sonuç
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
40.418 İtibar
16 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 1,181
