Ana içeriğe geç
HP EliteBook 820 G3 RAM Replacement
Neye ihtiyacın var
  1. HP EliteBook 820 G3 RAM Replacement, Back Cover: adım 1, 2 resimden 1. HP EliteBook 820 G3 RAM Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
    FixBot'a Sor
    Yorum Ekle
  2. HP EliteBook 820 G3 RAM Replacement: adım 2, 2 resimden 1. HP EliteBook 820 G3 RAM Replacement: adım 2, 2 resimden 2.
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
    FixBot'a Sor
    Yorum Ekle
  3. HP EliteBook 820 G3 RAM Replacement, RAM: adım 3, 3 resimden 1. HP EliteBook 820 G3 RAM Replacement, RAM: adım 3, 3 resimden 2. HP EliteBook 820 G3 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Pull the two clips on either side of the RAM sideways at the same time.
    • The top half of the stick will pop out of its plate.
    • Pull the RAM stick out.
    • Repeat this step with the other RAM stick.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nubia Pineda
79 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Class Fall 2022 Gateway, Team 1-1, Class Fall 2022 üyesi
GCC-CLASS-F22S1G1
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
How to reset BIOS password on the HP 820 G3 please? Many thanks.
Jaeram - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 1,318
